Article: Boost Fuel Economy With DynoJet's CMD
Results 1 to 2 of 2
    Microcosmic Clod BrettDawg's Avatar
    Los Angeles, CA
    Blog Entries
    13
    Default Article: Boost Fuel Economy With DynoJet's CMD
    At the L.A. Boat Show, Carl Chastain of DynoJet Research explains his company's Combustion Management Device (CMD), which can gain up to 20 percent in fuel economy on the marine 496 and big-block Chevy models by correcting the air-fuel ratio that the factory ECM puts out....
    Read the full article here: http://www.performanceboats.com/cont...-s-CMD-Aims-to
    EFI Technician DynojetResearch's Avatar
    Mar 2011
    Not only will the CMD Marine give you the ability to tune the air/fuel ratio of your engine for fuel economy, but it allows you to tune your EFI system for optimum performance, especially with aftermarket accessories like manifolds, filters, cams, etc.
