Good dui lawyer? For highway not boating - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 29 to 36 of 36
  1. #29
    Redding, CA
    Like has been stated, don't waste your money.
    There is nothing a lawyer will do to reduce the mandatory minimums that are SOP for first offenses.
    Even if he can, it will end up costing more with his fees.
    I learned mine with one offense. I don't plan on a second.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member Ballsdeep's Avatar
    Newbury Park
    Love everyones opinions. Right wrong or indifferent didn't the guy just ask for an attorney referral?
  4. #31
    Redding, CA
    Quote Originally Posted by Ballsdeep View Post
    Point is that it doesn't matter. Pick One.
    Cheap, expensive, or none at all, the outcome will be the same.
    Tommy
  5. #32
    Yucaipa, California
    Quote Originally Posted by BigDaytona View Post
    So i see the ticket today and he wrote her for .08 not .22. Does this change anything?
    BigDaytona, first off, i'm glad she's ok. It could have been much worse.
    As for the ticket, usually the cite won't say the actual BAC on it....cites will normally appear like this :
    Cvc 23152(a) DUI
    CVC 23152(b) <.08 bac
    That's simply the section used for anything over or presumed to be over a .08.
    Are you trying to challenge the PC for the initial stop? If the PC for the initial stop is not good, then any evidence found afterward is tossed out (exclusionary rule). If the stop is good (ie taillight out, speeding, weaving, etc) then it may be tough unless the off totally jacked up the case in the report somewhere etc.
    best of luck to both of you. any more ?'s let me know.
    1992 Eliminator Daytona 21'
  6. #33
    Sep 2010
    Default attorny
    Going to court without an attorney is like operating on yourself its crazy...
  7. #34
    Redding, CA
    Quote Originally Posted by ilmormark View Post
    For a DUI, you are not "going to court". You are going there to receive your' mandatory minimums.
    Hey, he can pay an attorney if he wants. The outcome on a DUI will be the same 99 times out of 100.
    In my experience, the prosecutor was out in the hall before court with a huge file box with the days files. He called each person that was waiting and told us before court what he would be seeking ahead of time. For every first offender, the minimums were the standard.
    If it was not, you had the opportunity to plead not guilty then lawyer up to fight it.
    There were in fact several there on first offenses that had counsel. They received the exact same as those without council.
    This scene plays out the same every day in every US city.
    Tommy
  8. #35
    Senior Member Wishful Thinking!'s Avatar
    Apr 2009
    Irmo S.C.
    I'm not an attorney and I've never played one on TV but I'll take his money.
    First boat - 1968 Starcraft 14' 40hp
    Second boat - 1982 15.5' Glastron 115hp
    Current boat #1 1987 Ski Nautique 230 hp
    Currnet boat #2 - 2005 Magic DB 425 hp
  9. #36
    Senior Member 26LAVEY525's Avatar
    Yucaipa
    Contact Felix D'Amico at D'Amico investigations. He is not an attorney but he is an expert witness in DUI. He can refer you to an attorney, then also retain his services. His specialty is finding an error in the procedure which will probably be the only way to fight this. It does work usually there is always some sort of mistake made in the procedure and this guy can and will find it. Also a good attorney is Milligan from Milligan and Beswick. Here is the links. with a BAC that high I would not show my face in court without an attorney.
    http://www.stephenlevinelaw.com/CM/C...iminal-Law.asp
    http://www.calif-legal.com/expert.php?fd_id=238
