Portable Boat Garage
Results 1 to 14 of 14
    The Insurance Guy millhouse961's Avatar
    Santa Ynez, CA
    Default Portable Boat Garage
    I keep my boat on the side of the house and am about done with having it sit outside all year long. Looking into getting a portable garage structure like this:
Name:	storage example.jpg
    ...and was curious if anyone else has one and has any tips? Best place to buy? Etc.
    2003 Cobra 270 Razor
    Senior Member PaPaG's Avatar
    Quote Originally Posted by millhouse961 View Post
    Be real careful, my buddy had one that he put up over his truck after getting a new repaint, secured it well or so we thought...after some huge winds in So Cal the thing came apart (broke a few of the legs midway) and a few of the legs did a custom zig zagging all over his hood, windshild and roof...needless to say the truck looks like crap now and he has to do a complete repaint and get a new windshield....Pay the difference and get a STRONG unit vs these temp units if you can...JMO
    Member dawnpatrol's Avatar
    Mar 2011
    I used one for years here in New Mexico to keep my truck and boat in. Even with the dry desert climate here in New Mexico if it was slightly humid out it would bead up and drip from the top inside of the portable garage. I just kept some old sheets and plastic over the vehicles to avoid water spot issues. I had mine mounted to the gravel surface ground with turnbuckles into concrete (3 on each side). Wind & Snow were not an issue although mine was a half round style. I believe mine was made by Cover It.
    Hope this helps
    Steven
    Santa Ynez, CA
    Quote Originally Posted by PaPaG View Post
    The issue is space. I would love to build a 3rd bay onto my garage, but between the garage and fence where the boat is is just barely over 10'. Even if the county ok'd only a 3' set back, it isn't enough space to build a permanent structure.
    Somewhere between Paso & L.A.
    I've got my boat in the same deal-Cosco portable garage- just make sure you anchor ALL
    the attachment points Redheads in concrete! I had 2 of them, and had to add half of
    one onto the other so it's 30 feet long, and tarp the whole thing, but it works I'm
    in santa maria, and the wind doe's get pretty bad.........
    Santa Ynez, CA
    Quote Originally Posted by Blowncat 509 View Post
    Wind doesn't get as bad over here in Santa Ynez as you guys, but good to know. With it all closed up, does the boat still get pretty dusty or is it not too bad. i intend to still keep the cover on the boat, but hate when I am taking it off and all the dust from the cover flies up and lands all over the clean boat.
    Scarab Racing Run_em_Hard's Avatar
    Apr 2009
    Utah
    Have you thought at all about a steel structure. Some places they are zoned as temp buildings thus not required to meet the same codes. I have looked at some of the carport type with full sides doors. They are actually really nice.
    Woodland Hills
    If you are not placing it on concrete, try using long lag screws to hold down the legs. Ours came from Costco with round base pads for the legs that could be screwed to the ground. The harder the soil the better.......
    I also use the lag screw method to secure our tent when camping, have long and short ones and just buzz them in with the cordless drill.
    WARNING!! Contents may contain sarcasm and/or satire, small children and pregnant women should exercise extreme caution.
    mud slinger plaster dave's Avatar
    winnetka ca.
    Have you thought about just building it like it's a patio cover? 3 poles out where the 3' from the property line is and lag a header to the side of your house. Then just paint/stucco it to match your house and roof it to match.
    I would even add electrical so you have lighting and fans to move air inside the boat.
    Don't sweat the "Petty", Pet the Sweaty!
    Senior Member Lumpy's Avatar
    Arroyo Grande, CA.
    Ditto
    Santa Ynez, CA
    Quote Originally Posted by plaster dave View Post
    I did consider that, but want it fully enclosed and if i set back 3' from the fence/property line, I am only 7' from the house and boat/trailer are 8' wide. Wont work
  13. #12
    Santa Ynez, CA
    Quote Originally Posted by Run_em_Hard View Post
    Yes I have considered that, but there really isn't enough room...the steel supports on either side of the structure would be too wide. As it is the boat fits in there pretty tight, so I need as thin a shelter as possible to fit around it. This has been a long dillema for me. I think I just need a bigger piece of land and build a whole new house and garage....oh yeah, forgot to water my money tree. Dammit.
  14. #13
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    http://clearspandealer.com/rv-camper.html
    I have had all of those cheap garages. Replacing covers,ends, zippers ripping, ball bungies. Did it for years. Clearspan makes the best one by far. I have two of them put together for 52 feet. Mine has a solar strip down the middle for light and it makes haet in the winter, but I wouldn't recomend that option to you guys where there's lotsa heat
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
  15. #14
    my buddy u-bolted 2x4's to the roof frame, and screwed corrugated sheeting to the roof and sides.
    made it very sturdy and weatherproof, but his was in the back yard- I don't think my neighbors
    would like the okie shed look in the driveway......
