help trying to go to river. impeller question - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 17 of 17
  1. #15
    Nordic 35' Flame Chico&Zeus's Avatar
    Anthem, AZ
    On both of my engines, the "Inlet" is the bottom hose and the "Outlet" is the top hose, also the Inlet hose is stiff heavy rubber while the Outlet is softer like the hose on top of a radiator. That is not to say that all engines are the same, just putting it out there that this is how mine is.
    R.I.P. Chico & Zeus I miss you both.
    small member spam's Avatar
    On the water
    Quote Originally Posted by Chico&Zeus View Post
    Thanks for the reply
    I used the bottom hose (from the drive) as you stated which was the one marked "left out" on the housing. "Right out" went to the motor. Inlet hard hose and outlet soft as you said.
    Seemed odd neither had a marking for inlet.
    Thanks for all help hope everyone had a great weekend
  4. #17
    Member bigmike58's Avatar
    Quote Originally Posted by spam View Post
    if you want to double check it..go over to Roke trailers (near your house) and look at my boat and compare..my boat has been there for a week otherwise I would have taken a pic for you..bm
    zombie you are seriously one screwed up dude. Good thing you decided to be on welfare for a living. Because you are way to stupid to have made it in the real world. GN7-
