Home improvement projects suck
Results 1 to 2 of 2
    May 2011
    Default Home improvement projects suck
    I was adding a light to my patio I had to tap into a light ceiling fan on my patio seems easy enough I run the wires take the fan down hook up the wires put the fan back up turn on the light no new patio light turned the fan on new patio light comes on no big deal took the fan down switched the wires put the fan back up turned the lights on no new patio light I pulled the wire off putting the fan up pulled the fan back down found the wire hooked it back up put the fan back up turned the light on new patio light works yea!!! fan dosnt work pulled fan back down all wires still hooked up checked voltage at the fan had volts after a break out of frustration I decided the fan motor must have went bad I would just put it up without the fan working( its still ill legal to shoot your fan inside the city limits in arizona) went and looked at it one more time theres a switch on the fan the middle position is off so now everything works I spent 5 hours and it was 4 wires yesterday I found a broken wire in a hundred wire efi harness in a sci 700 in less than an hour so when you have a problem with your boat and cant find it just remember my 4 wire fiasco sometimes your the windshield sometimes your the bug
    Jan 2010
    So Cal
    The important thing is that you had fun doing it
