How can I limit the amount of trim when using the trailer button?
    In the hunt! rsscoggins's Avatar
    Jul 2010
    North Texas
    Default How can I limit the amount of trim when using the trailer button?
    All
    The guy I bought my from worked with Eliminator to set up the boat with a higher x-dimension than normal. Good for going fast but not good for lifting the drive.
    If I raise the drive up all the way, the drive shower will contact the underside of the swim platform. (see picture for setup) Is there a way to limit how high the drive comes up? Or is there a drive shower cap that doesn't extend as far back or is more rounded.
    Thanks,
    Stacy
Name:	Boat pics 001.jpg
    Default Drive spacers
    Mercury makes drive spacers that snap on the shaft inside the ram, Probably take 2-3 spacers per ram. Cheap and easy to install.
    Jul 2010
    North Texas
    Quote Originally Posted by KONK View Post
    Thanks KONK! This is why I love this site - you guys are very helpful!
    Any idea where I can see a picture of these? Where can i get them? What is involved with installing them?
    Stacy
    May 2011
    Quote Originally Posted by rsscoggins View Post
    Stacy
    you should be able to get them from any merc dealer the part number is 15768a 3
