Petraeus's mistress (Broadwell) squeals.......
Results 1 to 14 of 15
    Default Petraeus's mistress (Broadwell) squeals.......
    Already miss the 310/562 2manymustangs's Avatar
    I'm thinking that her info is probably pretty solid...
    Pat Eason, the voice of reason...
    Floatin dirty Lavey29's Avatar
    Pretty big coincidence also that Patraeus went to Libya and conducted his own investigation into the attack and then all of a sudden gets outed on his affair. I suspect he would have some very damaging testimony and funny how they held all this secret until after the election also. Gotta hand it to O and the clown posse, they are astute liars and deniers for sure huh...
    There was definitely a deal being hammered out between them.
    Now POTUS hold an even bigger trump card over him rather than merely ruining his life, Patraeus will get criminally prosecuted for "breaches of security" if he squeals and nothing will happen to him if he doesn't.
    UD
    While this could be the reason for the Benghazi attacks, it is still just speculation. I also found it interesting how the article cited in the OP stated "insurgents entered the facility on September 11 and executed Ambassador Chris Stevens." From what I have read, Amb. Stevens died from smoke inhalation, there were no physical injuries to his body, and when he was taken from the consulate by friendlies to the hospital, he was still alive. It wasn't until he arrived at the hospital and underwent CPR for 90 minutes was he pronounced dead.
    Video: US ambassador killed in Libya attack: Chris Stevens 'given CPR for 90 minutes', says Benghazi doctor - Telegraph
    Video shows Libyans helping rescue U.S. ambassador after attack | Reuters
    Witness, video: Libyans found Stevens alive after consulate attack, rushed him to hospital - Winnipeg Free Press
    Quote Originally Posted by Uncle Dave View Post
    UD
    THe bigger question is "could Petraeus make Broadwell squeal?"
    What's a general or two OR the head of CIA in the quest for a good cover up by the lameO one, Clintoon's and the Chicago Mafia??? Collateral damage...
    Nothing new to see here, move along folks...
    Quote Originally Posted by ram78d10 View Post
    While all that may be true - its not the story.
    The other agents killed there - were actually CIA operatives, not just "guards" looking after the Embassy
    According to Broadwell Petraeus found out that when the attack started a call went out from the embassy to the guys in Delta Force who were standing by- but never responded - why?
    She also says that the CIA annex in the same compound was holding Libyan militia prisoners and that the attack was really an attempt to get their prisoners freed.
    This is all a unbelievably far cry from being caused by "a VIDEO." Which in light of all this information is nothing more than a lie to the public.
    Why didn't delta force respond?
    Uncle Dave
    Quote Originally Posted by 2manymustangs View Post
    Shes a woman scorned and already started squealing...
    UD
    Uncle Dave
    Maybe the WH wanted to keep the fact the CIA had prisoners at the consulate quiet for obvious reasons. I don't have a problem with that.
    From what I read, there was a quick response from the CIA annex a few blocks away. They secured the perimeter, reppeled the attack, and then searched for Stevens but never found him. They returned with the other survivors and 1 Dead to the annex. If the response quelled the violence, why would you send in DF? Also, maybe after hearing they couldn't find Stevens, Obama decided it wasn't worth risking DF in another possible Mogadishu like scenario. The fact is, we don't have the whole story, and people are overreacting when any new little tidbit of information comes out.
    UD
    Hell hath no fury.........
  13. #12
    Just Me snoc653's Avatar
    Eastern Iowa
    Your own articles contradict themselves. If he was found alive, he wouldn't stop breathing later after being removed from the smoke. While the effects of breathing heated air can close the airway, giving him CPR for 90 min wouldn't be the response to such a situation.
    If he was found alive and breathing, he wouldn't need CPR for 90 min. If he needed CPR, he was already dead.
    There was no crowd of protesters, you need a better source for your info.
    The attack wasn't over the movie, your article states a party line and as such nothing stated in it can be taken as truth. Other than the fact that there was an attack and people died as a result.
    Would the obvious reason be because they said they weren't holding prisoners on Lybian soil? Or the Executive order that was signed saying that the holding of prisoners on foriegn soil would no longer be done? By your own words the reason must be: Because once again they lied to the public.
    A quick response? The attack lasted hours, what is your definition of quick? And the CIA response was ordered to stand down. They did eventually go anyway and rescued some, but since they had not accounted for Stevens, DF should have been sent in to find the American Ambassador. And they should have been sent at the start of the incident.
    Now if they were holding prisoners at the counsulate, do you really think they would have only had 2 armed military members there to protect the consulate? If they were and that is all they had, then yes someone was grossly incompetant or had another agenda. And why would the CIA hold prisoners at the counselate when they had their own compound? And obviously they had enough force to repell an attack at their compound.
    Quit reading the zero press releases and start checking some of your facts before you blindly follow.
  14. #13
    Feb 2012
    OC, CA
    So what do you call it, attempted murder? When they set a fire with fuel because they couldn't get thru the bars to shoot or behead him?
  15. #14
    Thing is no one would be reacting at all if the administration didn't try to bury all this with a fairly tale a third grader wouldn't buy.
    With each new bit of info the story is more and more concerning as to how it was handled.
    Wouldn't you agree that this case is much deeper than Islamic anger over a video?
    I understand omitting certain facts but I despise being spoken to like I am a child by any administration.
    UD
