How do I...
How do I...
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    Default How do I...
    Post either a pdf or a word docuemnt so it will be printable to the viewer.
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
    The Earth
    Blog Entries
    24
    Quote Originally Posted by rampgirlll View Post
    You should be able to add a pdf or a word.doc as an attachment to a post just as you would a photo.
    Jun 2010
    Ft Worth
Name:	brick order pg 2.jpg
ID:	116425Click image for larger version.
Name:	brick order pg 1.jpg
    like this???
    Super Moderator
    Apr 2010
    those are jpg images (pictures) you should be able to load pdf or word.doc directly and they will likely open with a link. did you try that.
