Long blocks & used engines
Results 1 to 1 of 1
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Default Long blocks & used engines
    We have 2, (yes a matching pair) of 599CU LONG BLOCKS or Complete Engines
    Dart 10.2 Billet Cap Block
    Crower 4.500 BB 4340 Crank (Internal Balanced)
    Carrillo 6.635 Rods
    JE 4.603 x 1.270 Pistons (approx 8.87:1 compression)
    JE Moly/Hastings Rings
    CP 220w ENS Pins
    Clevite H Series Bearings
    Andrews Hyd Roller .647/.647 lift, .258/.260 duration @.050, 114 lobe
    Crane Hyd Roller Lifters
    Manley Push Rods
    Rollmaster Dual Timing Chain Kit
    Melling 10778c Oil Pump w/ ARP Shaft
    AFR 357CC CNC Heads
    -Tucker Seats
    -Manley 2.300 Intake Valves
    -Feria 1.900 Exhaust Valves
    -ISKY 9925 Hyd Roller Springs
    -Manley Cups, Retainers and Keepers
    TND Aluminum 1.7 Shaft Rockers
    LSC Internal Balanced Flywheel
    New TCM Valve Covers
    Optional Oil Pan (fit application)
    ETC, ETC, ETC
    Complete Long Block, ready for a very friendly Nat Asp set up or Light Boost Engine!
    Long Block $16,400.00
    Complete Engine $23,950.00 (w/out Exhaust)
    Complete Engine includes: Intake, 1150 Dom Carb, Complete MSD Ign, Oil Adapter/Cooler/HP6 head/Plumbing, Complete TCM Engine Acc, Engine Water System, etc, etc. Basically complete, run up and ready to install!
    Please call for any questions! -Eric
ID:	366953   Click image for larger version.
ID:	366961   Click image for larger version.
ID:	366969   Click image for larger version.
