Why would my block be filled with block filler?
Results 1 to 2 of 2
    Member specrocz's Avatar
    Nov 2009
    SE Mich.
    Default Why would my block be filled with block filler?
    I picked up a 21' day cruiser last fall and ended up having to winterize before I could take it out for a spin. While winterizing, after pulling the exhaust manifolds and removing the drain plugs on the block, I discovered a hard solid material behind both plugs. My best guess is this is Block-fill. What I don't get is why would this be done to a marine 454 Chevy? The prior owner didn't know about it and so far doesn't have the information on the building of this engine. If anyone knows why fill a block and what benefits or liabilities of having a filled block there are, please reply to this post. Thanks..
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Quote Originally Posted by specrocz View Post
    Email me a few pictures and I can help inform you of what you have. -Eric
    [email protected]
