FST High Flow Fuel Filters and Billet Mounts
Results 1 to 1 of 1
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Default FST High Flow Fuel Filters and Billet Mounts
    The RF500 was designed for high-performance, racing and marine applications to provide superior fuel/water separation and fuel filtration at high fuel flows. Using the same design and high efficiency coalescing filtration technology available the RF500 Filter goes a step further in providing additional water and debris holding capacity. Designed for use in gasoline, racing fuel, ethanol and methanol and can be installed on either the pressure or suction side of the fuel system.
    The replaceable FloMax 3 micron, spin-on filter incorporates a unique internal dual gasket/o-ring combination. The totally self-contained spin-on filter requires no messy and questionable canister cleaning, eliminates back flushing common with in-line filters and totally eliminates any chance of fuel system contamination. With the QuikSeal™ filter sealing system, there are no o-rings, gaskets or seals to leak or swell. This system is ideal for racing where extra capacity is needed and is OE with several offshore, high-horsepower, race engine manufacturers. This is the same filter you would you would find on the Mercury Racing 850HP up through the new 1650HP racing engines and is a great upgrade for any other performance engine.
    Available for the RF500 FST Filter is the Teague Custom Marine Billet Aluminum Filter Mount. Available in Left or Right Hand Inlets the Teague Custom Marine HP Billet Fuel Filter Mount has 3/4" NPT In and Out and is engineered to promote maximum fuel flow with superior filtration.
    Available in Polished, Pewter, Blue, Red, Black and Purple.
ID:	469545   Click image for larger version.
ID:	469553   Click image for larger version.
ID:	469561   Click image for larger version.
Name:	mount with filter.jpg
