496 mag complete engine package
Results 1 to 1 of 1
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Default 496 mag complete engine package
    Price reduced 10/27/15!
    Good/Take-out Mercruiser 496 MAG (385HP) complete engine package. $12,000 complete
    (plus freights if not picked up @ TCM).
    * 496 MAG @ 224.1 total hours, 100 hours @ idle. Engine is in great shape and ready to install. Includes feel mounts and s-pipe tubes.
    * Bravo "Magnum" transom assembly in good condition/Merc spec with trim sender and limit sender, also includes brazil manifold assembly.
    * Bravo 1X outdrive with 1.50:1 gear ratio. Has skeg guard (can be removed and holes patched, or any skeg repair work done for additional costs). Oil was clean and clear of metal. Includes 24p RH bravo 1 propeller.
    Please call for any spec/tech info. -Eric
Name:	496 engine small 1.jpg
ID:	802114   Click image for larger version.
Name:	496 engine small 4.jpg
ID:	802122   Click image for larger version.
Name:	496 gimbal small 3.jpg
ID:	802130   Click image for larger version.
Name:	496 drive small 1.jpg
ID:	802138   Click image for larger version.
Name:	496 prop small.jpg
