496 Performance! 496 Performance!
Results 1 to 11 of 11
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Default 496 Performance! 496 Performance!
    Senior Member rshrp2003's Avatar
    what are the performance gains
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by rshrp2003 View Post
    20-30hp, as normal. Some more, some less. Depends on application, elevation, tailpipes, etc.
    Full Throttle Marine did an excellent test on 496 exhausts. They didn't test CMIs, but all of the gains will be similar. None of them are more magical than the other.
    Look under Performance Projects
    http://fullthrottlemarine.com/
    Valencia, CA
    Default 496 E-tops
    Hey you guys!
    We are getting a few sets in next week to do some tests with Powerboat Magazine on a 27 Nordic Thor. Give us a call and we can give you some numbers true gains! We are thinking they are going to be in the 35-40 HP gains and a 10% torque increase!
    TEAGUE CUSTOM MARINE
    661.295.7000
    Shop or Browze 24/7 @ www.teaguecustommarine.com
    Member scotco's Avatar
    Arizona
    Quote Originally Posted by Teague Custom Marine View Post
    Hey you guys!
    661.295.7000
    I’m curious on how the testing went with the new CMI E-Tops?
    I have a 2009 Conquest Top Cat II with a 496 HO and I’m interested in a set of these.
    Senior Member Singleton's Avatar
    Carlsbad, Ca
    Any update on these, or do we need to wait for the article to be published. If we have to wait, can I call and get details, very intereted in these.
    My choice is now between the CMI E-Tops or the Dana's.
    2007 26' Ultra Shadow Deck
    Arizona
    Any word on the e-top testing? Results?
    Valencia, CA
    Default 496 E-tops... The Answer!
    Hey you guys... Sorry we have been busy so it has been hard finding the needed time to get you the info, but here it is!
    We did a new set of 496 E-top (polished) headers on a Nordic 27 thor. Starting from the install, it took our mechainc about 6 hours to install and have running (powerboat magazine was doing a atricle and had to take many pictures). Our guys said it was a fairly easy kit to install or easier that others... The coolest thing I personnaly think is you get a full Stainless tubular header, but they do not require tail pipes so boats with s-pipes make power for much cheaper!
    Performance increases we a killer kicker! CMI dynoed the 496 E-tops @ 40 honest HP increase w/ no computer modification and 10% torque. We personally do not recommend to re-map the computer due to fuel costs and its not really worth it!
    Back to the Nordic, I do not know all the previous info, but here is what happened. The way the boat was proped, they were under in RPM so there was no prop change needed, they just got the full potential RPM @ about 5100... That particular boat picked up 3 MPH, and dropped a full second or more thru it time numbers (getting onto plane and mid range). For you guys who like the punchy sound, it will open it up and make her a little throatier for you!
    Overall, the CMI 496 E-tops are the system to go with.. From affordable prices, easy install, to performance, you really can not go wrong with these kits! IF you have any questions please give us a call!! -Eric
    Satin $2995.97
    Full Polish $3495.97.
    ALL SETS IN STOCK
    661.295.7000
    "We Have Everything but the Water!"
    Arizona
    Satin $2995.97
    ALL SETS IN STOCK
    661.295.7000
    Thanks for the reply. I will be giving you a call.
    Nov 2008
    Default headers
    i was talking to a guy on this forum and he said hes using the new cmi headers on a 496 ho and with roller rockers he gained 9mph, what would rockers do to reliability and do u recommend this upgrade???
    Valencia, CA
    Default 496 upgrades..
    9 MPH... That is a killer increase! It sounds that he was in a set up where he was down on prop pitch and power... I always and mostly recommend the header system and a K&N Filter system, but the (Crane or Scorpion) roller rockers would be a smart reliablitly move! They are not going to give you more power, but will stand up to anything you throw to that power package! -Eric
    661.295.7000
