454 mag F/I
Results 1 to 2 of 2
454 mag F/I
    Senior Member Mrs.HLB's Avatar
    Corona, Ca
    Default 454 mag F/I
    Hey Bob
    What exhaust system would you recomend for an upgrade on this motor it is rated at 385 hp might add the k&n filter also nothing wild just a little more umph it in a cole 26 s 1996 with a bravo 1 outdrive 150.1 no prop on it yet.
    Thanks for your time
    Mark
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    Quote Originally Posted by Mrs.HLB View Post
    Hey Bob
    Mark
    Hey Mark,
    The best bang for your buck exhaust system I would recommend would be the CMI 454/502 E-tops. They are a direct bolt on replacement system that does not require tail pipes. They are available in both full polished and a satin finish. You will see about a 10% hp/torque increase!
    Satin (13186)- $2799.97, Polish (13185)- $3280.00
    If you plan to make bigger power down the road or you want to get the most out of your system now, I would recommend the Std CMI E-tops, that require tail pipes. This kit will allow you to run a bigger cam shaft with out having to consider a reversion problem. All of our shelved E-tops come with the SS Distribution tubes.
    Platinum (13062)- $2753.32+tails, Polished (13028)- $3257.83+tails
    I would recommend to run the K&N filter. The more air you get into the motor along w/ the more air out (with the new exhaust), the more power you make!
    Eric
    TEAGUE CUSTOM MARINE
    661.295.7000
    www.teaguecustommarine.com
