/\Yes thier is. 049 are a good head for a semi stock motor with some bigger valves. The 781 have more performance potential with even bigger valves. Its a can of worms and the 049 with a 2.19 intake are a good setup.
Thanks Cas but please next time print for this Old mans eyes.Had to get out the mag. glasshopefully this will help you. The 781 heads have 256/114 cc port size runners, with 118cc combustion chambers.
The 049 heads have 255/119 cc port size runners, with 122cc combustion chambers.
It's really a toss up on which ones to use as the 049's flow more but the 781's will give a little more compression. Personally, I went with the 781's and had 2.19 intake valves and 1.88 exhausts put in. The same can be done to the 049's without any issues.
Costco has those specs in the handy economy packs !I know what you mean. When I turned 46 it seemed 1 day I could see just fine and the next I needed glasses. Now that I'm 52, I've had 7 new pairs of glasses that are getting stronger and stronger.sphss
Tom great imfo but what do you think are the best heads to start with? I have 781s But don't want to waste money,trying to do the best the first time.Heres a great website and valuable resource for anyone chasing casting # info Tom
http://www.mortec.com/castnum.htm
