Would trade for a street rod, muscle car RUNNING the wife and I can drive around Florida.
This engine is fresh. Started not ran.
Complete Engine And Turbo System minus intake manifold fuel and ignition system $10,500
Dry Sump, Gear Drive, Shaft Rockers, Billet Caps, Pac Springs, Straub Cam Fresh Turbos Procharger Race BOV Precision Wastegates. Custom 304 Stainless Headers Etc. New Tilton starter
385 CID 10.2 compression Turbos and fuel system supporting 1,800 + HP on methanol
Block:
010 block. Billet caps. Main and head studs. Main girdle. Deck holes drilled tapped and plugged. “O” ringed. Filled to bottom of water pump ports
Rotating:
Cola crank std/std and Cola I beam rods I have owned these Cola components for 20 years. JE Pistons Total seal AP rings.
Heads:
Brodix SR series aluminum professionally ported. Ferrea Competition Plus intake valves and Ferrea Inconel exhaust valves. 1.625 Pac springs. Titanium retainers. Tapped for extra cooling between valves.
Valve Train:
Custom max effort Straub turbo cam. Morel solid lifters. Smith Brother push rods. LGM shaft rocker system. Gear drive.
Oil System (Choice):
Melling Select and chrome oil pan
Dry sump 3 stage geared for 7,800 RPM. System 1 filter. Oberg scavenge filter with turbo scavenge plumbed in. Peterson dry sump tank with integral return filter.
Turbo System:
2 Garrett TV77 66mm turbos brand new cartridges. Powdercoated compressor housings, T-6 flange 1.15 AR. 2 1/4 stainless turbo headers by Ron Shearer. Precision turbo 46mm wastegates. CO2 system, tank, regulator, control valve
Misc.:
New Tilton starter, SFI balancer and flexplate, powdercoated tall valve covers.
Long Block with turbo system $10,500
With electronics $14,500 EFI, Ignition, 16 volt alternator battery and charger. Datalogging CO2 Boost Control and supporting components
Don't need the headers? -$2000
New port Richey, FL 918 two six nine 8084
Discussion Starter · #2 ·
Also available for purchase.
Fuel System:
Tuned for Methanol supporting 1,800 HP. Enderle 990 belt driven pump. System 1 EFI filter. Precision Turbo 225 lb/hr low impedence pencil injectors. Custom Gorr fuel system 3GPM manual injectors with CO2 operated valve. Electric prime pump. Magnafuel bypass regulator.
Ignition/Electrical System:
MSD crank trigger. Custom cam sync from MSD billet pro stock distributor. New F.A.S.T. XR-1A coils. MSD plug wires. New 16 volt alternator front mount. New 16 volt TS racing battery and XS charger.
Electronics:
F.A.S.T. XFI 2.0 EFI system brand new motherboard, dual injector drivers, datalogging, 10 pressure transducers. All sensors.
F.A.S.T. XIM igniton control. New.
Air intake:
Single plane powdercoated EFI intake manifold. Port matched to heads. Wilson elbow, Accufab 90mm throttle body, Procharger red race BOV, powdercoated charge pipes.
Discussion Starter · #3 ·
Bump 1468
Discussion Starter · #4 ·
Bump
Discussion Starter · #5 ·
Bump
Discussion Starter · #6 ·
Bump
