Is a 5.3 not wet sleeved like the 5.7?
What is a detailed impeller?
If mine breaks 100mph I'll be tickled pink for this coming season atleast. This is my lake boat lol.
Does your hull bow in like cardboard when you put much more than a finger on it? Mine does... And makes crackling noises sometimes.
Gonna be a learning experience for sure!
a 5.3 is a 3.780 bore, 5.7 is 3.905 cleaned up. gna take a .125 over bore to get to where a ls1 piston fits, and big hp lsx guys are telling me that the 5.3 block will go that easily and still be capable of big boost without a half filled block, so that's what im doin. diamond pistons can be bought offa ebay for 600 delivered, rods 350bucks, and if you're using a 5.3 crank, it'll have to have material removed from it to be balanced to the ls1 forged pistons and hbeam scat rods. the ls1 pistons are lighter than stock 5.3 cast pistons and the 5.3 crank is the same as a ls1, but the ls1 crank is crossdrilled and lightened stock, so bobweight is lighter too. so that basically allows ya to bore a 5.3 to a ls1 bore, use ls1 forged pistons/hbeam rods and you'll still be lighter on the rod/piston combo than the stock 5.3 stuff, which makes it easy and cheap to have balanced
devil nooooo mallory!
devil
yes sir, my hull weighed 340lbs with the pump intake in it, and the sides are veryyyy thin, im painting them black so while on the lake, i dont see thru the hull and make myself nervous
st
i love the look of the hull, and from the pics ive seen of them runnin, they jus look killer
grn as lite as they are, its a no brainer to use a smallblock, a bigblock is gna make them react odd and might get me pitched out, so ive stuck to keeping it as lite as possible and have been building the inside of the hull to offset my own weight with the fuel cell, battery, turbo , everything i could is hung to the passenger side to offset my 165lbs
if that blown engine you've got is making over 700hp, i bet it'll do 100+ easily
