It's worth more to the nostalgia guys than it is to you. If you can get it cheap pic it up and resell.Are rebuild parts still available for 1951 331 hemi's?
I found an old car today with one still in it complete down to the belts.
figured it would be worth picking up if I can find parts.
If it's a 1951, then it's a Chrysler (not a Dodge, Plymouth, or De Soto). They have the cast-in belhousing on the back of the block (1951-1953). Save that engine for the sake of hot rod history if you can, even if you flip it to an enthusiast that is more into it than you might be.
LO
The 1954-1955 331 heads are the popular ones; the 1951-1953 331 heads have smaller valves and different ports, etc.Alot of the old timers believed the 331 was the best head of the series.
One did pretty good in this years Engine Masters Competition:
http://www.popularhotrodding.com/en...ates_and_results_sponsored_by_sam/index1.html
Nice looking engine, but still only 336 inches so at 1.5 hp per cu. in it would be 504 HP but they do weigh a ton. This engine finished 3rd in the competition.
What would you put the engine in ?
S CP
I figured I better try and get it before it got crushed or something.Good looking oil pan on that engine!!!
Paul,
Try Hot heads, we (Stefs) does a ton of work for them, good guys also. If you can't find the number I will get it for you.
