1 - 2 of 2 Posts
Up for sale is a nice 1968 19ft Howard Flat Bottom with a 426 cubic inch FE Ford. This boat has been in the family for over 20 years. It runs and drives great. The hull is very solid and sits on a nice competitive trailer. The engine is fresh and was built by George Striegel with Clay Smith Cams. The 10 degree Hallcraft v-drive was built by Tom Bently, has 16% gears and whirl-a-way. It also has a steel strut made from Hondo Boats, new ruder from Barber Welding, Russell stainless steel fuel tanks, Auto Meter gauges, stainless steel steering cables, Hill 2 blade steel prop, D21 shaft log seal and stuffing box. Registration for the boat and trailer are up to date. All pictures are current. I am asking $12,500. If you have any questions feel free to give me a call. This is a very fun and reliable boat and thanks to D21 products it doesn’t even leak a drop of water.
Thanks,
Kenneth 714-943-6353
FE Ford
It comes out to be 426 cubic inches..
•750 Holley Double Pumper
• Edelbrock Victor 427 Intake
•Edelbrock Fuel Plump
•Edlebrock Aluminum Heads with Clay Smith Cams port and polish
•T&D Shaft Rockers
•JE pistons
•SCAT H-Beam Rods
•Eagle Crankshaft
•Cloyes Timing Chain
•Canton Oil Pan and windage tray
•Clay Smith blue printed oil pump
•Clay Smith Solid Lifter cam shaft (264/264 duration at .050 .630/.630 lift and 108 lobe separation)
•Smith Brothers Push Rods
•ARP bolts throughout including Rod Bolts, Head Bolts & Crank Studs
•Mallory Billet Distributor
•MSD 6AL ignition Box
•Trailer Also Has Brand New Tires
Thanks,
FE Ford
•T&D Shaft Rockers
•JE pistons
•SCAT H-Beam Rods
•Eagle Crankshaft
Still for sale?
1 - 2 of 2 Posts
