1 - 20 of 33 Posts
just getting into vintage speed boats and i got this kona and can't find any info out there for it. who made it ? where? are there any resources? I blew the engine up easter weekend, so of course its already @ the machine shop. Of course I'm ppumping it up alittle more. where can i find info on this boat or something similar? HELP!
Stop right where you're at. Call the machine shop and tell them to throw that motor out and start looking for a Chevy. No, I'm not kidding. Since you're just getting into this, there is no reason to go backwards. This is boating, and depreciates fast enough without having to dump more money into that Olds. Trust me, I know. I went through 2 motors in 4 years. I had #3 still running when I sold the motor. My first one blew the first week I had it. My wife did the same thing you did. (Assuming) Hold it to the floor for more than 15 seconds, suck the oil pan dry, start welding the bearings together at 4800rpm and knock knock knock. You can build it faster, quicker and throw all the money at it you want, but its not going to fix it. Although, its the beginning of the season, and if that motor is truly close to being finished...run it. Don't abuse it, and start doing some homework on why Olds are hard to expect longevity in a jetboat. The HB site was loaded with great Olds threads, but we're new over here and don't have the archives built up yet. Yes, there are Olds guys out there, Maxwedge, Travis Hathaway, and maybe one more...
I was one of those guys, and have never looked back.
Good luck.
PS: What were the circumstances when your motor blew? What went?
I fused #7 and #8 bearings in one motor, snapped a crank in another.
ohh cmon guys, the olds motors are known for thei rproblems but there are fixes out there that will cure the problems...
considering you have the block and all components depending on what blew and what was damaged keeping the olds will be the cheap way to go for now and get you back on the water quicker, istead of having to source all new chevy parts (exhaust, motor mount kit, and all the esential engine accessories to make it run)
Have the machine shop "race prep" your block. Enlarging, deburring, and polishing all your oil passages INCLUDING the heads and lifter galley, and be sure to match the head gaskets to the passages. Purchase the correct oil restricters from an olds performance parts manfacturer NOT MONDELLO!! Be sure to run the correct clearances for a "race application" for the pistons ring to cylinder clearance, considering boat motors are at a higher rpm when compared to a car engine,Fully balance the motor and use arp studs on the bottom end, rods and heads and you should be fine. My current setup includes
olds 455 fully race prepped fully studded
keith black forged 10:1 pistons
slight port job on fully rebuild Ka heads (want edelbrocks)
comp cams Xe274 camshaft .230/.236 duration @.50 .520/.523 lift
king race berrings
and both heads have had the rear tapped for direct oil return to the pan
offenhauser tunnel ram 2 edelbrock 750 carbs (lookin for holley 450's)
mallory ignition system
bassett Ot headers
mondello 10 qt pan and pump
This motor should last me quite a while, im not out smashing the gas all day long either. I just wanted a nice jetboat to cruise with the occasional foot to the floor. The build was going to originally cost me $1500 But with having to source a new block, crank and rods it jumped to much more.
limit the rpm to about 5000 and you should be good. I currently run an A impeller and get 64 mph on the gps. That was with my old stock 455 setup, this motor and fresh pump should get more hopefully!
Just be sure to address the oil issues! and please please dont run a high volume oil pump ;)
I agree Matt, There's no real reason to replace the motor if the motor can be rebuilt. Oiling has been the main issue with the Olds motors and that can be fixed. Depending on what you really intend to do with the boat, I'd go back the way it was, with a little over build and have fun. Summer is coming and a boat sitting in the driveway due to motor issues is going to suck!
There are a lot Olds out there living and breathing just fine on the water. If later on you want to get radical then you can do that on the side and be ready to make the change all at one time. Think about this, to swap out to another motor right now, you will need the motor, the headers, the mounting rails, just to name a few. Headers, new, $1000.00, mounting rails or stringer mounts, upwards to $500.00, motor, who knows what it'll need, and then some wiring changes. Not to mention a new drive line and the list can grow from there.
Want more power later on, then build on a stand and gather the parts as you find the deals. Get ready for summer now and have fun.
You know as well as I do that you WAYYYYYY overpriced that stuff. Try looking for some used ones. Motor, $500, Headers $200, Rail kit, $250, Stringer kit $75-100. If money isn't a hurdle, then neither is a Chevy. Those 2 things you mentioned and priced cover ONE machining. Then you have to address all the oil issues and do this and mod that and when THAT motor blows, you'll be afraid to take it over an idle. Then you're into ANOTHER motor. By now, you could have had a nice mill for what you have into the Olds.
i think a safe number to play with to completly switch over to a chevy would be close to 4500 possibly more. Depending on what condition the chevy motor is in when you take it to the machine shop. Think of atleast 3000 in parts and labor at the machine shop to build a reliable chevy, and the additional parts to get it runnin. If youve got the cash make the change go with the chevy, if you wanna be on the water this summer.... run the olds.
Who said anything about taking the motor to the shop for any kind of machine work? Thats right, you did. You can pick up used race motors or mild runners cheap. Hang on, I'll be back with a quote from you, and some numbers.
king race berrings
bassett Ot headers
Maybe its just me, but that sure seems like a shit load of money for a "jetboat to cruise with". How much do you have into the machine work and hardware? What heads are you running? What rockers?
Thats just me talkin, i have never bought an engine and just thrown it into somethin. Every motor i get my hands on i always take it to a machine shop and have it gone over. 1 for reliablility reasons, and 2 so i dont have any interesting suprises ruin my fun. And id like to know where i can purchase a "race motor" for less than $3000... Doesnt matter if its a fresh motor, or one thats been ran, show me a reliable race runner that is under $3k.
NW Spectraholic
If money is no object then by all means get a Chevy or Ford and builld the hell out of it. However, if you are boating on a budget like a lot of us, then you can make the Olds live. Just don't fall into the trap of building it up too far. Like the others have said, the max RPM on a 455 is around 5500 so it makes no sence to put a huge cam in it or a tunnel ram (except for the bling factor). ;)
The large crank journals build a lot of heat so they need a lot of oil to stay cool. The upper main bearings should be hogged out to match the big holes in the block and either restrict or redrill the cam bearings to funnel more oil to the mains. Some think this reduces oil geting to the "top end", but that oil comes from the lifters through the pushrods. You can restrict each of the lifter bores or buy a set of restricted pushrods to keep the valve covers from filling up with oil. You need to run the crank loose also (.0025-.0035") and notch the rod sides to let that hot oil out a little faster. With these mods I'm running a HV oil pump (with HD driveshaft) with no problems. You can usually drill out the oil drainback holes in the heads at least 1 drill size bigger with out breaking into the headbolt holes.
Being an Olds guy doesn't mean I'll stick with them forever. I'm collecting Chevy parts too. ;)
You should get to know some of the local track drivers. They are a hell of a source. You know, dirt, circle, oval racers. Not Nascar.
At the current moment im just under $3000 for machine work and some of the parts, comp cam 1.6 rockers
The heads are as i listed... Mild port work with full rebuild on a set of big valve Ka heads. i would like to get a set of edelbrocks but that for later
Workin 6-7 days a week i dont have much time to hit the tracks to get to know anyone... Ive got friends in the drag racing industry that help me out when need be. But with me having the olds for now, they arent much help. Starting in fall im gonns slowly start to build up a chevy motor. Most likley wont be done till end of next year.
From PAGE 1 in SPAM:
bassett twistie headers for BBC. ceramic coated. the coating is dull from being run without water. could stand to be recoated. otherwise the headers are in good shape. $350.00
Page 3
This came off my boat when I bought it & replaced the motor. I already had a driveline made for my setup so this one is for sale. Built in PTO flange. $75. plus shipping.
PAGE 4:
Look, a complete motor for LESS than your machine work...
complete 454. pan, starter, Edelbrock t-ram with single top, edelbrock 750 carb, Mallory unilite dist, moroso v-covers, polished perf log exaust with cooled solid flange. 4 bolt block, std bore. steel crank. casting #'s 3999289 and date code is 12/71. Mortec shows 71-76 454. Looks ugly but turns over smooth. First $1400 takes all............
SHOULD I KEEP GOING? I think I blew your number theory out the f'ing water. :|err:|err:|err:|err:|err
You're going to dump more money one way or another. Listen, I'm not trying to convert you. You can do what you want with your money. But you're going to spend a lot more sooner or later on that Olds. With Ka heads and that cam, you're going to break something. Stock heads don't like anything over .5 lift. Guess what happens to pushrods when that happens? :)hand
CHA CHING.
like i said in my initial post... It would have cost me $1500 for the build just for machine work to be put back to its original condition pretty much stock. After i found out i had to source a new block, crank and rods due to the maintenance and abuse of the previous owner the price jumped up a bit. At the point i said screw it im building it the way i want.
That 454 is well priced. BUT like i said i wouldnt drop it in and go. A full disassemble and freshen up is what i would do. No clue as to what an engine has gone through, or how the owner before maintained it. New rings and berrings for sure. Im not tryin to sit here and fight over what it costs.. I know what it costs, and im sure you do as well... We have both been there numerous times. So buy that 454 and throw another $5-600 at it to be fresh, and dump that single carb top.. ;)
my olds scares ya.... ;) its ok you can admit it :)hand
CHA CHING.
Thats why i have all the correct things done to run that cam. Trust me im not throwing that cam in with a set of stock heads and springs... All the clearances have been checked, the correct springs installed... This motor is fine.
Geez, I think you guys scared him off.
Fact of the matter is that if its in a Kona, the olds will probably be fine. Not the best built boat and definitely not the fastest. If its still in good shape then I'd just run it the way it is(with the olds)
A properly built olds will do just fine and can take a beating just as well as a checvy as long as its built right! If you stand on the throttle for 15 seconds and it blows-the engine builder messed up!
If you just want the olds rebuilt-go over to realoldspower and talk with those guys. They will set you straight. Lots of haters on this site when it comes to that motor. Usually its people who dont know what they are doing.
1 - 20 of 33 Posts
