A few months I acquired this 19' 1976 Kindsvater from a friend, it was ordered in 1976 and never rigged. Currently the plan is a mild BBC with EFI (I know I could be dealing with hell on the EFI, but I have a plan if all else fails then I will resort to carbs), the rigging is being done by Don Mumma at Fantasy Rigging. The plan is to rig it modern with a vintage touch, Here are some progress pics from when I got the boat to where it is today. The plan is to have it complete for Flat Bottom Boogie, if I miss that date it will be at Wades Paradise New Years Day. The trailer needs a bunch of work, so i made a dolly for the boat, so Don had an easy platform to work from. You can see in the pics how tight the v-drive math turned out, adding the whirl-away really made it a tight fit with the coupler and seal, the safety collar will need to be placed underneath, motor will sit low and at 3 degrees. The seats will be bench front and rear and the exhaust will be over transom, I was hoping for through transom but it will be too tight after motor placement. I still need to make decisions on interior color/pattern/material, polishing and anodize color.
