Status
Not open for further replies.
1 - 11 of 11 Posts
This is Hard for me to Do, but sometimes in life you have to make sacrifices!
1978 Bahner Bubble Deck $17,500 - Will consider selling Less Motor
I Finished this boat in 2014 - Every single bolt and part (Except Hull and engine Block) was bought New on this Boat.
Original Gel Coat with No Stress Cracks, Has some minor scrapes and scratches as it is over 30 years old.
Interior done by West Coast Marine Interiors - All double stitched with upgraded Vinyl.
Low Profile Black Bimini Top
Billet Steering Wheel with shotgun drilled Steering, Billet diverter switch (No wires hanging down)
Auto-meter Carbine Fiber Gauges with Black Bezels
Black Aluminum Rub Rails with Black Rubber
Powercoated Black Aluminum Dash Trim
Flush Mount Billet Gas Caps
Flush Mount Thru Bolded Billet Bimini Brackets
Lightening Billet Foot Throttle Pedal
Billet Water Control Valve for Headers
Audessy Battery with Billet Battery Box
Stereo
Alpine Deck with Alpine Marine controller on Dash
Apline Digital AMP
4 - 6” Kicker Marine Speakers
Kicker 10” Subwoofer
Berkley Pump with Split Bowl, Droop and Ride Plate by Jack at MPD
MPD - Bronze A-B Aggressor Impellar
MPD - Loader and Shoe
Blue Nozzle Insert by Place Diverter
Hydraulic diverter with Lock out.
17-4 Shaft
Intake was re-set and sealed.
Delta Pad with Speed Coat
557" Big Block Ford - Full Roller Motor Built By Mark Godfrey @ California Performance
Eagle Crank and Rods
RacTec Pistons
Comp Roller Cam and Lifters
Comp Cams Stainless Roller Rockers
ARP Studs with Comp Cam Stud Girdles
Fully Machined CC ported ProComp 3v Heads - with Manely Stainless Valves
Aftermarker Valve Guides and Valve Seats
Isky Tool Room Valve Springs
Manley Retainers with 10* Locks
Comp Camp Roller timing Chain and Gears
High Volume Oil Pump
Dooley 14 Quart oil Pan with Windage Tray
ARP Bolts Thru out
MSD Ignition with Rev Limiter
MSD PRO Billet distributer
Holley 1000 CFM carb from The Carb shop
Basset Twisty Headers - Ceramic Coated
Aeromotive HiFlow Fuel Pump
This Boat is a Sleeper and Runs very good, please let me know if you have any questions.
Troy 951-850-4774
20150331_175355.jpg 20150331_175443.jpg 20150331_175516.jpg 20150331_175914.jpg 20150331_175526.jpg 20150331_175859.jpg 20150331_175330.jpg 20150331_175433(1).jpg 20150331_175618.jpg 20150331_175609.jpg
This is a clean boat! If I get some paint sprayed on my '68 GMC soon, I just may throw it up for a quick sale. If someone doesn't snatch this up soon, I'd sure be interested. Just too many pokers in the fire at the moment. GLWS!
Nik
1 - 11 of 11 Posts
Status
