1 - 2 of 2 Posts
Hull built by Brad Collins. Hull #7 of 12 ever built
Dominator Jet- Hardened shaft, New HCM inducer, Stainless AB impeller, Droop, And Aggressor Hydraulic Diverter. (pump is machined for ratchet) Double drilled and studded bowl and droop
Lightning rail kit, 2-17gal tanks, Imco Superflow fuel selector switch, Blue top Optima battery.
Custom made boat cover. Single axle trailer with new wheels and tires.
Motor is a 2010 ZZ502 bored 30 over(509ci), Eagle 6.535 h-beam rods, forged crank double key’d
JE flat top pistons, Total seal rings, Comp Billet timing set, Clevite bearings throughout motor, Custom grind .650 lift Bullet cam, Morrell hydraulic lifters, Comp pro magnum roller rockers,Trick flow push rods, MSD btm ignition with timing retard knob, BDS 8-71 Blower with Holley 750s, Milodon timing cover, Magnafuel prostar 500 fuel pump and 2 port retgulator. Canton Oil pan, New Bassett Headers.
True 100mph jet boat. I have over $28k in build. I know I won't get that but be real with offers. Will also trade for nice outboard hull(allison, Hydrostream Venom or mirage) Boat is located in Louisiana. Will separate hull and trailer. Turn key $21k
1 - 2 of 2 Posts
