1 - 2 of 2 Posts
need help shift hard to get out of gear and poor preformance shift interruptor switch does not work when i depress it it has 2 switches on it it is a alpha drive also check it with ohm meter and appears to work ok one swicth has 3 wire deal basicly going to ground the other one is 2 wiredeal
Could be a bad cable stretching or out of adjustment. If the switch does not work and it checks out okay then you need to get a wiring diagram and go through all the wiring. I would start by checking the rigging on the cables all the way down to the outdrive. Make sure everything is in rigging specs.
1 - 2 of 2 Posts
