what year I think one is an in gear switch witch tells the computer that the engine is in gear the other is the shift interupt switch I think its normally closed then opens to interupt the older ones were normally open then closed to interupt if the idle is to high the computer will ignore the signal you can test the switch with an ohmn meterno neither one works
