1 - 1 of 1 Posts
383 Chevy, 350 4 bolt block, 400 ci crank, pink rods with ARP rod bolts, T.R.W. pistons, balanced fresh build new aluminum heads, stainless steel valves, roller rockers, aluminum intake, 750 holly carb, hydraulic flat tappet cam 240 degrees at .050 .510 lift. Ready to drop in jet boat stainless steel plumbing, HEI distributor, top mount starter. All mounts and u-joint assembly. Hook up fuel and wire connectors and GO BOATING. $3,750 OBO.
Call: (623)-842-0898
Text: (623)-910-0901
1 - 1 of 1 Posts
