Status
Not open for further replies.
1 - 3 of 3 Posts
V-Drive 4 ever
Selling the Engine that's in the Camaro. it's a 383 Small block Chevy and is estimated 510hp at the flywheel.. selling as a long block with Intake, oil pan , flex plate/balancer, timing cover .. Will remove the Carb, Distributor, Starter, Valve covers and air cleaner and all the accessories on front of engine. Will leave the Aluminum water pump on it.. 2800.00 . has approx 3000-4000 miles on it.. Located in n.cal near Sacramento area. 530-333-1047 . still in car for now..
Youtube video of it running today.. https://youtu.be/fkGDQ1HKMlA
here's some info on it from the Builders site..
Pistons 10.3 to 1 piston set (runs on pump gas)
NEW STD STD 3.75 steel crank with superior wear sized and indexed.
forged steel rods
Moly File Fit Rings...
cam bearings...
King Race series bearings std -std rod and main...
Custom HYDRULIC ROLLER high output cam lifter set ..
double roller set...
chrome moly pushrods
Hi-volume- oil pump...
Hi Performance pickup...
steel drive...
7qt Deep oil pan.
After market - aluminum timing cover...
pioneer head bolts...
BIG 7/16 rocker studs
blue - gasket sets... - TOTAL PARTS YOU COULD SPEND BUILDING YOURSELF 3700.00 plus heads and rockers =$6500
NEW ALUMINUM CYLINDER HEADS Bowls blended
Features - - -severe duty 2.02/1.60 valves plus ... 1.45 springs 10 degree super locks comp cam parts.. 7/16 studs guide plates. gasket match p.c seals. chrome molly retainers,with mild port work these heads are better than ANY OUT BOX HEADS YOU COULD PUT ON FROM SAME MANUFACTURE
Hi performance roller rockers-1.6 ... (not the cheap stock stamp steel)
Features - awesome power range 2000-6500 WE Recommend A 2300 stall. lopey muscle car idle.
streetable and will run vacuum access
Total parts and labor value = $6500
V-Drive 4 ever
Discussion Starter · #3 ·
unsure just yet.. but either leaning towards a LS7 or well built LS3 .. or possibly looking at doing a 427 or 434 Dart SBC.. the 383 is fun but i want more and a 5 speed..
1 - 3 of 3 Posts
Status
