1 - 14 of 14 Posts
Frozen Hoser
540, afr 357cnc heads, crane 268741 hydraulic roller, whipple 4.0
1102hp at 6000.
peak torque at 3400 was 1075 lbft and it held over 1000 to 5800.
AKA Blownjet 468
would be curious to see the results with the 335cnc's at that rpm, with everything else the same- those are some good #'s tho:)devil
Good job.
What kind of boat is it going in ? Make sure to come back and let us know what the boat does.
What boost, compression, and type of fuel ?
Frozen Hoser
Good job.
03 25 Daytona
10psi, 8.2:1 ON PUMP 91
Hopefully water testing tomorrow.
Was asking about the 8.1 because the cam PN says 8.1. I guess you were using this cam for the 4-7 swap firing order? Very impressive @ 10psi
Frozen Hoser
Discussion Starter #12
water tested this weekend. first crack, -2 sportmaster lower with 1" spacer, 1.36 gears, 32 labbed bravo.
119 bouncing the limiter at 6100
Platinum Member
height difference. I would have preferred to but my buddy wanted to keep it all under the stock hatch.
I understand, good power #'s
We have a couple of conversions from the quad rotors to the 5.0 liter in the winter work schedule for us to think about
Your boat is hauling the mail , bravo's are a good overall prop for the money, but at the power level you are at I would try some better props for sure, maybe a 5 blade herring hydromotive,BBlades
1 - 14 of 14 Posts
