1 - 9 of 9 Posts
i',ve got a Chevy 402 short block out of a 71 truck. 2 bolt mains, steel crank. I'm thinking of throwing a set of 990 heads (once i find a decent set) on it and trying to make roughly 500 or so horses. i figure if i keep it under 6500 rpm's it'll stay together. does anyone have any info or advice on this?
maybe something i should know before i attempt to run this block.
any info would be appreciated.
it's going in a first run XH511. 12 degree Casale with 15 gears.
thanks.
I'm famous !
thanks.
396/402 are fine in a boat - cruising rivers and a little jet boat action . build it with a blower and a set of ls6 rods a steel crank and a decent valve train and you will have years of fun .
Do take the time to go threw the oiling system . I think early blocks had the groved rear cam bearing - this can be a issue !
thanks.
Before you spend $$ on a set of 990's, you might want to look at these. The 990's will make that 402 pretty lazy under 6500.
http://www.performanceboats.com//showthread.php?t=20842
Some guy
That is correct, on a 65, maybe 66 block, but the 1971 factory 402 should be fine.
I have a nice set of 990's for sale, but agree that you are probably better off with 049's.
Dang it... Sorry Barry...didn't mean to step on toes...
well what i f i was running say 12.5 to 1 comp. a big solid cam and a tunnel ram with two 750's?
Some guy
You didn't in the least Scott, I was giving him a push towards a set of yours actually.
If you are going to try and turn higher rpms,, as previously stated, perhaps over 6500 the larger heads might work a little better.
I'm famous !
it will be fine - just buy race gas . and rev the piss out of it , When it gets mad at you . YOU will know it ;)
1 - 9 of 9 Posts
