have 1990 Baja 37' withtwin 454/425hp carbureted, one of this have misfire at high rpm 4200 and up, I installed a new ignition coil but I still have the same problem
Thanks for your help
Dan
misfire
Did you look at your valve springs? May not necessarily be broken, but they could be weak due to age and fatigue. Just a thought.
Darin
the problem has to start when I was using the power trim high speed, I had a problem on groung of my battery, I repair this problem, but now I have the same problem without using the power trim at high speed, I thought that the ignition coil had been damaged because of my gound problem on the battery, I change it for a new coil without good result, I was not made to check my valve springs because I thought rather a electric problem, but if I can find no other solution I will check the valve springs but for that I will have to remove the engines!
rollin on the river
Change your distributer cap. I had the same issue changed plugs wires rotor and cap found 1 inch crack from over tightening.
pull your distributor out push the shaft and gear up check for play or wear at top of shaft this can create a high speed miss
