454 .030 over.
Under 20 hrs, ran 1 race in compjet class, $6,500 obo,
Engine builder's build sheet avail.
Located in Parker, AZ
Eagle rods
Roller cam
Aries 13.5 - 1 pistons .030
Forged steel crankshaft
Holly 850
Clevite 829P 20 main bearings
Clevite 743P 20 rod bearings
Durabond CH 12 cam bearings
Cloyes billet timing set
9.100" pushrods
9.950" pushrods
Pro Comp cylinder heads
Roller cam springs
Pro Comp Shootout intake manifold
Pro Comp stud girdle
Pro Comp head gaskets
Pro Comp rocker studs
Pro Comp guide plates
Pro Comp head studs
Aluminum timing cover
Comp fuel pump pushrod
Teague SS water plates
Comp 419-16 Endure X lifters
8 NGK 4554 spark plugs
10 qts Brad Penn 40 wt racing oil
1 set 4 bolt main caps
Mag and inspect 4 bolt block .030
Balanced assembly
Sent from my iPad using Tapatalk
Eagle rods
Roller cam
Holly 850
9.100" pushrods
9.950" pushrods
Roller cam springs
Pro Comp head studs
Balanced assembly
