1 - 9 of 9 Posts
"Try it Now!"
where do i find a high performance fuel pump??
If your old mechanical pump is the one that has the inlet, outlet, and vapor/overflow line going back to the carb i'd like to take it off your hands (if it's still working) Mine is 35 years old, i'm sure it's running on borrowed time.
Does anyone still sell a mechanical "marine rated" pump for 455 olds? The engine I just bought has a mech pump with the outlet - inlet - vapor port configuration but I think the diaphram is shot because the crankcase oil has a strong gasoline smell and seems thinner than it should be. It could also be leaking from the carb so im not sure. My other engine (also marine and just as old) has the automotive style outlet - inlet only configuration so who knows if it is really necessary.
Is there a good way to pressure/vacuum test these old mechanical pumps? Just pressurize each port to 4-5 psi and see if it leaks over time?
You could hook your vacuum guage to the inlet side of the pump and crank the motor over, should pull a good vacuum in the 13-16 range.
Discussion Starter · #7 ·
it is only 2 seasons old and it has an inlet, outlet, and one with a rubber cap on it? so this is a vapor overflow?? where on the carb would this be plumbed???
tahiti boss, mine is automotive. can be bought new at most part store. this is why i am inquiring about maybe a higher output pump??
malcom, what did you finally end up runnin for a fuel pump???
Mine is plumbed (Q-jet) to a port at the rear top of the carb, just below the flame arrestor. It appears to simply vent to the area just inside the flame arrestor by the rear (larger) upper butterflies.
NW Spectraholic
I still have a standard parts store variety on my new boat, but I have the RobbMc off my other 455 just waiting for this one to give me any trouble at all. ;)
1 - 9 of 9 Posts
