More info
what is a good gap for plugs for this motor
What distributor are you using? A standard type, (point) ignition is .035.....An HEI type stocker would be .045-.060, depending on the coil output. A Magneto type ignition w/o an external transformer, .018-.020. A mag w/ext transformer, refer to unit instructions as there are several variables........If it is an aftermarket distributor/system you can always go to their web site for detailed instruction sheets. Hope this helped you, Ray
Damn Ray your like a walking "Olds repair manual" :D Good job !
Easy ones
Well I'm old and slow, so I have to jump on the easy ones once in a while. I actually sold auto parts when we sold more points and condensers than HEI caps and rotors. We also stocked Y block Ford valley gaskets...........Ray
PS Also SDN1A starter drives for every GM starter in the world!!!!
