1 - 3 of 3 Posts
468 Short Block. JE Pistons set up for Blown/SC, 7.75:1 Compression, Carillo Rods, Steel Flywheel, 4 Bolt Mains w/ARP bolts, Cloyes dbl roller T/chain, ARP Studs,
Solid Lifters, Teague Marine Turbo Cam, $3400. CAll Greg 818-585-8541
Also available as long block with 990 heads/SS Ikanel exh, SS intake Dbl Springs (one head is cracked, repairable), Roller Rockers, ARP rocker studs, Edebrock Alum intake manifold, 10 Qt Oil pan, . $4000
1 - 3 of 3 Posts
