1 - 20 of 23 Posts
Steal gm crank
Gm rods ARP bolts
New ARP main studs
New KB pistons
New comp push raods
New comp lifters
New Clay smith cam
New summmit balancer
Lower end was spun balanced before assembled never been fired $1250.00
Purple headed member
Steal gm crank
Gm rods ARP bolts
New ARP main studs
New KB pistons
New comp push raods
New comp lifters
New Clay smith cam
Hey Einstein....A long block would include the heads. What you have advertised is called a "short" block.
So either cough up the info on the heads or admit your stupididy and call it a short block.........
The member
YA, what he said you focken Donkey!
"Stupididy" is that a word? Might want to try the spell check button.... just sayin.....
It's part of the joke......
And yes, "stupididy" is a real word. It means the same as "stupidity" but is spelled differently. It's French.........
Whats the compression ratio, what kind of pistons, specs on cam... what kind of clearances.. 4 or 2 bolt?? im interested... im located in sacramentoo..
Pm me the full monty!!
Discussion Starter · #16 ·
It's a two bolt Studded , and line honed Cam spec's are .630 .630 @264 solid comp. Are 9.8-1 keith black
If it has heads consider it Sold.
1 - 20 of 23 Posts
