1 - 3 of 3 Posts
725hp carb to pan, 4 bolt block, ls7 chevy steel crank tufdrided standard standard, ls7 chevy steel rods with polished beams, has 7/16 arp bolts, arp main studs, arp head studs,13.1 manley pistons with floating pins, bullet roller cam, crane super duty lifters, 990 sqaure port heads fully ported, comp cam stainless steel roller rockers 1.7 ratio, comp cam high tech one piece push rods, dom intake matched to the heads, sfi bal, sfi flex plate, hooker comp headers ceramic coated, 1050 brad urban dom, super sucker 1" spacer, polished valve covers, polished timing cover, moroso race oil pan and pump... $5000 complete on this bbc stout motor
small member
Hours, location ?thanks
RPM Range?
1 - 3 of 3 Posts
