I replaced the oil in the out drive. Replaced it with the standard high performance mercruiser oil. I changed the engine oil...knarly black...definitely needed to be changed. Replaced with royal purple. Changed the fuel filter, and changed out the batteries.After changing everything out, I put the fake lake on the drive, cranked it over with the kill switch OFF turn bring up the oil pressure. As soon as I saw 40 lbs. I flipped up the kill, and it started and ran for about 10 seconds, then died. The buzzer started beeping so I took a look at the outdrive reservoir and it was empty. I filled it up and the buzzing stopped. I went to start it and nothing. What I have tried thus far....I didn't put fuel in filter when I replaced it so, I yanked it off and filled it up with some 87 and put it back on; nothing. I found the shaeder primer valve, depressed the valve and a small amount of fuel gently bled out. I switch the ignition on and off about 10 times, rechecked the shaeder, nothing came out. I had a buddy depress the shraeder valve as I turned the ignition switch on. Tried that a good 20 times. Still nothing comes out of the fuel rail. I pulled off the fuel filter to make sure there is still fuel in it and it is still filled to the brim. I do hear the pump switch on for about 5 seconds each time I turn the ignition switch.I double checked all the wires going to the batteries and everything looks in order. The boat ran 2 weeks before I started wrenching on it. I'm stumped in this one and know it has to be fuel related, but what is the next step?
