Contact Extreme1 on the boards..he might have a hp500 for sale:hmmm:...you could contact Whipple and put one of their blowers on..or do like we did ..pull the 496 out and opt for the blown 588i would like to up my power,what are the best least expensive options
Do a search on here for 496 HO and start reading. This has been asked SEVERAL times and lots of the info you are looking for is already here.i would like to up my power,what are the best least expensive options
Disregard that. ^^^^^^^^^^Buy a different motor. Don't waste time and money. It'll save you more in the long run. 500 HP or a 525
1) change exhaust Dana or CMIi would like to up my power,what are the best least expensive options
I was going to mention the TURBULATORS, but forgot. Thanks for bringing that up. That was a "feelable" change in mine. Sound also. It has been dyno'd at 7hp difference, but it sure feels like more. Taking a 2.5" restrictor (turbulator) out of a 3.75" hole definitely helps flow.1) change exhaust Dana or CMI
2) do the whipple ecm upgrade
3) get some more air into the motor compartment
4) try a labbed prop
I installed extra vents into the Warlock got some more COOL air into the more ..it picked up.....I did everything except the exhaust ( removed the "turbonators" off the exhaust) ....
We put the same motor into the Eliminator and it ran good..lifted the hatch about 2 inches on the motor picked up RPM's ....We tried this on Exteme1's Laveycraft and it picked up some RPMS also...
Yeah, ask the other guy on here that went through the cost and effort to change to that - for 5 mph.I know where 2 500efi's are?
Didnt say that is or isn't the way to go just said I know of two of them???Yeah, ask the other guy on here that went through the cost and effort to change to that - for 5 mph.
I have 04 katchina with a 496 ho. After looking into what it wold take to make it go fast i found out nothing. The 496 ho is a great motor the way its is. Not a good motor to build up, so if you want go fast change motor. Or do what i did, I bought a runner bottom that goes well over 100mph.i would like to up my power,what are the best least expensive options
yeswill it add 80-100 hp??
if they have over 500 hrs on them they should be freshed up.I know where 2 500efi's are?
Yes....however, you should run the 3.5 boost setting and NOT the 5. The cast pistons in our engines are thin at the top near the ring-land. ANY detonation will tear chunks off and start to implode the motor. Has been done several times.will it add 80-100 hp??
