1 - 14 of 14 Posts
​$17, 500 each
889 [email protected] 8 psi
Mark IV bowtie blocks.
548 ci
4.530 bore, 4.25 stroke
651 crane cam (244/256 632 lift 114 lsa)
Piston oilers
Spring oilers
Machining by Borowski Race engines
Fresh this spring from short block up.
2 year old boost referenced Quick fuel 1050 carbs
Canton 10 qt oil pans
Construction
* Six Trap Door Baffles
* Oil Recovery Pouch
* Crank Scraper
* Bolt In Slosh Baffle
* Built In Louvered Windage Tray
* Three 1/2" NPT Bungs
* Provision For our Pan Mounted Dipstick
* Powder Coating & Brass Plugs For Corrosion
Protection
Eagle cranks
JE pistons
Molnar Rods
Dart iron eagle 345 heads with 40 hrs worth of combustion chamber and port work done by High Flow Heads.
Ferrea super alloy exhaust valves
Competition plus intake valves
.135 wall Trend 3/8 pushrods
Stainless Crower rockers.
Intake: offset rockers for better valve pattern
Tool room springs
Stage 4 BDS 10-71 blower gone thru at Dyers. Restripped and replaced bearings 3 years ago.
Schumann High flow oil pumps
Daytona ignitions with map sensors. ( easily build 3D timming maps based on map/rpm/load/boost)
Daytona Boxes also have many other features like idle stabilization, start reatrd etc etc.
New MSD distributors
IMI HI TQ starters
Completely rewired and pre-wired for warning lights. (senders installed)
Water/oil temps, pressure and Fuel pressure.
Fuel set up for return to tank
Set up for pre oiler or easy oil changes with built in pump.
Brass seapumps
Hexadjust timing chains
Available with or without Drive Guardians ($2500 each)
8 plate bellhousing coolers for motor and trans
reason for sale: Boat sold without power
Ready to drop in, no corners cut on these builds whatsoever, ran perfect all summer.
With stainless marine Exhaust it`s rigged to run water thru manifold first before motor to pre-heat cold lake Michigan water. No condensation issues and a great idle with warm water .
Standard bypass also available.
1 - 14 of 14 Posts
