1 - 2 of 2 Posts
Selling a tall deck bow tie block that’s mostly filled with block filler. It’s also a oring block with brass lifter bushings, and a bore of 4.560. Comes with a manley 4340 crankshaft that’s been double keyed freshly magged and polished, the mains were ground down 10. Also comes with manley steel rods and je pistons. All components have about 5-8 hrs of run time on them since last rebuild. The motor overheated last outing which is why it’s now currently apart. The crank was serviced and repaired due to cooked main bearings. Rods and rod bearings were luckily all in god shape. The pistons still look good and are round with minor scuffs on them with the exception of one which may need to be replaced. Also I have a short deck mooneyham blower manifold with spacers to fit the tall deck application. $2400 for everything listed above. Give me a call or text at 559-
827-3655
Sent from my iPhone using Tapatalk
1 - 2 of 2 Posts
