1 - 11 of 11 Posts
Lurker
Sonny Bryant Billet 4.375 Full Counter weight (8) Crank, Cross Drilled, Double keyed snout, Full REM polish (7 dyno pulls)
Carrillo 6.535 Enduro Rods (7 dyno pulls)
JE Dish Pistons for 4.605 bore/standard valve angle (new)
Trend Performance .185 wall Pins (new)
JE Pro Seal Hellfire Rings 1/16 top-1/16 napier 2nd-3/16 oil (new)
This rotating assy is machined, balanced and ready to run (just fit your bearings and file rings). The pistons come with a full CMM sheet, and are pin fitted. The crank and rods have 7 dyno runs with a 12-71 blower. The parts were for one of Mr. Hendrick's offshore boats. They made the dyno runs and due to the extreme low end torque output he decided to go to 598 EFI N/A engines instead.
All work done by HMS engines. NO JUNK!!!!!
I will get pictures and piston dish cc up later in the week.
$4000.00
What heads where on it? What was the static CR?
Thanks
Travis
Lurker
Discussion Starter · #3 ·
I believe the heads are Reher/Morrison Bowtie's. I have the heads at home so I will try to get the casting numbers for you at lunch.
Not sure what the static would be with these pistons but will cc one this afternoon and post that info also.
I believe it was 9to1 with a 118cc head but I will double check.
Lurker
Discussion Starter · #5 ·
861 Bowtie heads
The pistons pour 12.1cc
Sorry about the phone pic.
I'll get better pics when the crank comes out of the REM machine.
Quit talking about some silly assed engine , and fix your damn boat :)hand
1 - 11 of 11 Posts
