replaced seals on prop. shaft....greased it,,took it out boat stayed dry,,,first time I cranked it up it started looking like a sprinkler,,what did I do wrong???!! It's a snapring,,simple set up thought it was a no brainer,,turns out I'm the one with no brain,,,,water p/u off bottom of boat, run though v-drive gear box and into coupleing that holds the seals.. thanks ,,keith
