41 - 56 of 56 Posts
anyone know where I can buy internal exhaust flappers? Everywhere I find them theyre discontinued. And all ebay has are the ones you clamp on the outside of the exhaust. Any way that I could just make them myself?
If the bells are cast brass(chromed) or aluminum, I think Glenwood still makes them. You should be able to get them thru RexMarine.
LINK: Rex Marine exhaust flappers
Discussion Starter · #42 ·
I was able to make two out of some plyable rubber I have, But not sure if the rubber is thick enough not to bow due to water pressure exurted into them and get them stuck inside of the pipe. I pressed on them with my hand and they were able to take some abuse, and still flap out as well.
Are there any 'snails' at the end of the wet exhaust manifolds? Kinda don't see any in the pic. What's the differential in height from the manifold down to the tip (guessing that this thing has some monster stringers in it).
CC
Just looked back at the stern pix and see that the tips are WAY low on stern. How many inches of fall is there from tip to log?
Discussion Starter · #44 ·
there are no snails on it, it has 6-10" of fall to the center of the exhaust dumps.
Info on skv
I own a 1974 24' skv with original metallic gel coat. I am the second owner and got the boat in 1996. It's a deep v, shaft driven, with a 455 olds. You'll find this is one of the bests boats on the water. When everyone else is bouncing around your boat will cut right through. If there's something i can help you with...get in touch.
Hello to all, I am new to the forum so bare with me for the first few posts.
I recently bought a 24' SKV powerboat and was wondering if anyone had a little more info about these boats, if they're worth owning? basically do I have a good boat or not?
Also the boat is a direct drive so I didn't quite know where to post it so move it where needed. I figured the V drive was the closest thing to a direct drive.
But heres a little info on the boat.
1975 24' SKV day cruiser. 440 chrysler. Direct drive. has nice paint but the motor needed work. Had to put a new water pump on it and rebuild the other. Has 2 water pumps for some reason? can anyone shead some light on that? It has a nice cooling system on it with the heat exchanger.
here's the juicy stuff, picked the boat and trailer up for $800. Has good interior, no rips, the hull is solid, no holes. Engine did not run. Waterpump threw the bearing and turns out that was it. I swaped out the pump, put new batteries in it, drained the fuel tank and cleaned the lines. Turned the key and fired right up. Thing is a beast but I already love it to death. But cannot find out any info on the history of the boats. I read somewhere that Hallett bought the molds from SKV.
Here's some pics, lemme know what everyone thinks.
Thanks
John Cronin
Nice looking Sun Chariot. I worked for SKV starting early 1976 till about the end of 1978, almost two years total. They were not building this model when I started but I knew about them. Gene had changed the deck and built a more traditional day cruiser style with seats under the forward cabin. Gene Racine was originally an engineer and I believe worked for worked for Aero Jet. He was always thinking of something new, whether it was a new design boat or re-designing the hardware or motor/drive system. He wanted something different when he was designing the taller cabin version of your boat. All the other companies were adding side windows to the cabin; he added those to his design and then added a window to the front to make better visibility when riding in the cabin. The first few boats had 2 windows and he changed to a one piece window. He showed the new cruiser at the L.A. boats show in January of 1976. Later that year he heard other companies would be adding windows to the front of their day cruisers, so he did them one better. He spent most of the winter months to design and build a complete wrap-a-round window. He designed and built all the tooling to form the glass and bend the metal trim. Gene was not a follower, he always did things his way and was never was one to conform to what others did. Your Sun Chariot is a good example of his thinking. Traditionally most Day Cruisers of the day used V-drive or jet drive power. He thought outside the box and came up with a low profile direct drive boat ski boat. In1976 he came up with a new twist for the boat show. Instead of putting a jet or V-drive in the show boats, he installed OMC stern drives with 235 hp, Ford 351 engine and the 24’ had not one but two motors and drives. At the next boat show almost every manufacturer was installing a stern drive in at least one of their models. Gene was ahead of the stern drive movement in performance boats. He built a twin stern drive version of your model for a friend of his and he had a 21’ version with twin stern drives. Later he built a special twin OMC 351 engineversion of the 24’ that he used in the Catalina Ski race. For 1977 he switched from the OMC units to MerCruiser. Merc had just come out with the 250hp 350 package and also the new 454 TRS package. He built another race boat with the larger TRS drive and a turbo charged big block Chevrolet. The name of the race boat confused many people. The boat was yellow with blue trim and the name was “BigRed”. He named the boat for his daughter who had red hair! SKV also built a pair of boats for the United States Coast Guard. I did not work there at the time but I did here stories about them. One story had to do with a dispute between the Coast Guard and Gene. The build required a center pole for towing disabled boats. The Coast Guard official who came to view the boats had an issue with the structural design of the pole mount. Gene insisted it was more then adequate for the job and the Coast Guard said it was not. So to prove his point, they all took the boat to the lake to see what it would do. At first they thought Gene would just pull another boat to test the structural design.That was just not Gene’s way! Instead he tied a heavy duty rope to a big piling at the dock and the other end to the pole. He idled out till the rope was taut and then floored the throttle. The pole did not move and the Coast Guard accepted the boats!
All of the SKV models had DNA that can be traced back to the first model he ever built. The first model was a 21’ cruiser that came in along deck or short deck design. Gene named his boat “SKV” which meant “SK” design with a “V” bottom. The bottom was somewhat flat and was what Gene called a “stepV”. Most hulls have a bottom that is made of a 2 flat surfaces that come together at the keel forming the vee of the hull. The lifting stakes would be small flat surfaces added to the bottom. If you removed the strakes you would still have the flat surface the keel to the chine with no changes or upset in the surface. The step v design is multiple flat surfaces with the first one starting at the keel, extending out about a foot wide and has very little vee at the transom and changes its angle as it approaches the bow. The next surface was about an inch higher (the step) and also changed its angle as it approached the bow. The outer surface again stepped up about an inch and also changed its angle. Look at the transom of your boat and you will see the step design. The first hulls did not have a turn down for a lifting strake, those were added when your hull was designed and the vee was increased at the transom and at the front. After the 21’ came a 19’ model that was nothing more than the 21’ hull with the freeboard cut down. Next came the 24’ day cruiser and it was built off a stretched version of the 21’ with extra freeboard. The 24’ was the model theCoast Guard ordered. The Sun Chariot was next; it stated life as the 24’ cruiser and they changed to the bottom, adding more Vee and cut the sides down to make a lower sleeker design. It was now time for a new 21’ so Gene started with the Sun Chariot and cut 3’ off it. The Sun Chariot got a new, taller deck with windows and seats in the cabin. By this time the original 24’, 21’, 19’ and SunChariot had been discontinued and SKV was building only 2 models, the new 21’ daycruiser and the 24’ Cabin Cruiser. During the time I was there they added two other models to the line. First was the 21’ cabin cruiser. This was done by grafting the 24’ deck onto the 21’ bottom. It still had the cool wrap-a-round cabin window and they moved the dash forward, decreasing the size of the cabin seats. The other model was the 22’ day cruiser. It started life as the 24’ and they just shortened the hull and lowered the height of the deck. SKV made a few model changes after I left the company. The 24’ got a restyle of the deck, but retained its wrap-a-round window. Another deck was built for the 24’ bottom that was the re-birth of the Sun Chariot. The deck was not as tall as the cabin model and it featured much more outside seating area. The new Sun Chariot also lost its direct drive power and was now stern drive powered. The last model was a new 20’ ski model. Just like all other models it too started life as a current hull and changes were made from there. There was one unique version of this boat built and was used in the Power Boat magazine test. Gene cut most of the deck away, leaving only a section of the front. It was something like a whaler design with a larger deck up front. The power was a direct drive but instead of the drivers console being forward of the engine, it was at the rear of the boat like a cracker box.
It was sometime around the early 80’s that Gene was getting tired of the marine industry and was ready to call it quits. He contacted Nick Barron of Hallett boats and sold the company. Not only did Nick get all the molds but he also got one of Gene’s employees. Jim started working for SKV a year or two before me and was with Gene up to the sale of the company and then started working for Nick. Hallett built a few of the SKV models, but I think some of them were a little time consuming to build (especially the 24’ with the front window) and things were changing in the industry with the openbow cruisers becoming more popular. Last I heard Nick still had the molds but stopped build the SKV’s about a year after purchasing the company. I also think Jim is still working for Hallett.
I was only at SKV for a few years, but I came away with more knowledge then others in the industry could get working two or three times that at other companies. My time and experience working with Gene and Jim is something I valued and has stayed with me in all my other endeavors to this day. Someone once said that SKV did not build boats, they give birth to them.
I have some old magazine articles about SKV along with one of the last full line brochures. I’ll try to scan what I have and post pictures soon.
Mike
Great post itsmeagain...I bought a 20 from Nick and Jimmy
Great post itsmeagain!!...I bought a 20 from Nick and Jimmy in 1984.
Mine was a Volvo (Chevy)290 engine with a 280 outdrive, Hill nose cone and Volvo-hubbed Mercury Cleaver prop. It would get up and dance. Later Hill Marine made Thrasher round ear prop which I bought which was better overall.
They (Jimmy) cut down the turning fin because it whistled...but I replaced it with a stock Glenwood. It turned better and yes it was a great boat for skiing. For an 8 foot wide boat it got up on a 4 foot pad and threw a very narrow wake...I had it out on Mead in some very nasty water...and as long as I removed the Bennett trim tabs before the trip I could get the nose real high and get through it! Ha:)
That Direct drive 24 is the coolest thing! I had never seen one of those. I did however see the cut deck DD Sun Chariot 20 at Havasu.
It was also quite unique and good looking. That had to be a killer ski boat!
Its a lost brand but to those in the know its a pretty killer boat! My kids have a Malibu V-Ride now...but I still miss the old SKV-20.:yes:
I didn't know this forum existed I have a 74 skv day cruiser
This has been in my family since 1975 I grew up on this boat. It was my fathers and recently became the owner after he passed away. I owned a 2005 27ft hallett since new. Since I didn't need two boats as tough as it was I sold the hallett and kept the 74 skv. And what a boat she is. Still has the 455 olds and looks just about the same as the day my dad brought it home hooked up to his 70 delta 88. He knew Gene Racine. It is my understanding that only 2 of these were ever built in the metal flake green color. These are rare and are real head turners at lake. Don't ever sell it. It's ways a great conversation piece and frankly I haven't seen too many new breeds of boats that compare to these
SKV Powerboat
I had a 21' SKV. A great boat. Unfortunately I sold it in 1980. I'm now looking for another SKV. If you know of anyone selling theirs, have them email me at [email protected]
Thanks
John Cronin
SKV Boat Owners
I'm sorry if I'm stepping on this thread but I'm new at this form. I just bought a 1976 24ft Skv daycruiser and had it for 2weeks and the ball gears on the drive and the tilt are ruin and having hard time to finding info on how to fix it or even parts on these boats and help would be great.
My Peace
No problem, welcome to the forum. Sounds like you have an OMC "Stringer" outdrive; they used ball gears to make the connection where the drive tilts, and a worm drive motor to actually power the tilt. Do you have hydraulic jacks under the motor mounts? That's what it took to actually trim those PIAs. Unfortunately, those ball gears wear out nearly immediately if you run the motor with the drive up- it's not uncommon. The guys over in the Outdrives forum may be able to point you in the right direction for getting replacement parts, they are getting harder to find but not impossible.
My neighbor has a 76 24' stern drive SKV with twin small block Fords. The hull, deck hardware, and trailor are in good shape, but needs a new interior and one stern drive. What are these boats worth ? To say they are bilt like a bank vault is not an understatement from what I'm seeing.
you got any pictures
Hi. I am new so bare with me. I also have a 1975 SkV. Bought it a couple years ago. Took a couple pictures and wrapped it up until I found time to restore. The one I have has twin 235s in it.
If what I am reading on this site is correct? It may be the one boat built for racing around that time. I cranked motors over but did not attempt to start
Guy i bought from claimed they ran great when he parked it. Glad to see others with similiar SKV interest.
Mike
I would like to talk to someone like your self who knows a lot about the SKV boats I recently bought a 1977 24 ft day cruiser with the 454bbc and merctrans two MCM-D and I understand its supposed to have the TRS 330 out drive doesn't have the out drive on it or the engine still has trans and complete gimbal housing.
Mark R Thomas
41 - 56 of 56 Posts
