750 or 850 holly on a mild/stock bbc? and double pumper or vac secondary's
it will run "great" & if u stay out of the secondary's, ur fuel mileage should be the same...also...if u upgrade the motor in the future, u will have a good carb to work with...many more things u can do to it than a vac sec carb...just my .02 centshow will it run with the pumper compared to the vac sec. will it change my fuel mileage
its what was on the boat when i got it. just so i know why should you not run a vac carb on a jet boatyou should never run a vac carb on a jet boat. why would you!
My little 715 vac secondary on this 468 works great on my Jet! Throttle response is almost like FIyou should never run a vac carb on a jet boat. why would you!
