1 - 7 of 7 Posts
Ok, now that mortec is gone cannot find out what they are. Can someone please tell me what I have? 781 are the last 3 #'s.
Thanks
large oval port open chamber heads with small intake valves, work well with larger valves and some bowl clean up work, lots of guys love them 468-496 low comp mills.
Thanks, do you know what size valves were stock?
2.06 int x 1.72 exh and i think they have chambers in the 119-122cc range
heavy 3/8 valves should be maybe up-graded to 5/16 with the valve up sizing to lightin things up
well, with valves that small that could be why it's not very fast. not inhaling enough.
Pretty common upgrade is to install 2.19/1.88 11/32" stem valves. With a good valve job and some minimal bowl work they will flow over 300, up to about .650 lift. Good for 600hp easy and with more work and a little better flow they will go 700.
AKA Blownjet 468
Or in other terms, you got 1 of the 2 best open chamber oval port gm castings made.. 049 being the other;)
1 - 7 of 7 Posts
