1 - 9 of 9 Posts
So all else being equal if both engines make 750hp at 6,750 would the smaller engine with more compression ( pop) be more responsive, rev quicker and be funner to drive ?
Just asking :)bulb
S CP :)bulb
Too many unknowns.
What's the application?
Where's peak tq on both engines?
Are we assuming that the smaller engine has more compression, or maybe the bigger engine is just a bad combination? Maybe the 470 is a dyno queen and the 512 has much better average powe, or could be the reverse...
At least the thread isn't titled "something to fight over"... ;)
So the 470 more compression= race gas? 512 pump gas? I'm going with the cheaper pump gas combo if everything else is equal.:D
Or Seth, either one
Always cool when the underdog makes the cut, but... you know the old saying. Cubic inches are KING. :|err
Even if it is only 42 ci. That's only 7 ci short of 10% larger!
Now, the story changes if the underdog costs waaayyyy le$$.
If it's more than $1k less... The 470's lookin good to me! :D
Well the thought did cross my mind......;)
I was thinking a river race 19' 4 person jet boat. typical river racer play boat. The smaller engine has more "bang" per Cu in I was wondering if you could feel that in throttle response. If you've ever ridden a stock Honda old XR-600 with 9.4:1 compression and then a slightly pumped-up one with 11:1 man does that wake them up.
Other mods help and it does make more hp but the throttle response is a huge difference.
S CP
I thinking the 512. Like Steel said, the max power may be the same, but what does the inder the curve look like. You really can't compare the 2 XB motors because they are the same size with more compression. Power was probably up across the board.
Almost any engine with a narrower power band but with the same max ouput will be more if a maintanence hog. Jetting becomes more critical, as does timing.
In a recreational jet, I'd be all over the 512.
Living in a cage of fear
Which one came from a Suburban?????:)bulb
(Or in your' case, an Expedition):)hand:)hand
I was thinking about making it something like the 512" at 720hp at 6,200 and the 470" at 750 hp at 6,600 just to mix it up, assumming the boat is a typical weekend river racer 19' deal.
S CP
1 - 9 of 9 Posts
