... starting a project to replace the toe board and the side boards in my Bezer. First, the toe board is still in good shape but the access hole is huge and it's not glassed in all the way around. I planned on cutting it out and replacing it but was wondering if I could leave it there and glass another one over the top. None of the old toe board will show, so I'm wondering if there's a reason to take it out.
Next question is can I stain the wood to make it a bit darker and have the glass adhere as well as sanded wood. The existing balsa floor is way darker than the plywood so darkening it would be desirable. Based on what I've been reading, planning on using 1/2" marine plywood and some type of epoxy product for glassing.
Last question; should I plan on putting a layer of cloth on the backside of the sideboards. I figured I'd resin it for sure, but not sure if the back side needs a layer of cloth as well.
Thanks!!
Thanks!!
