Time for a full race prepped impeller, off the shelf stuff ain't gonna cut it for you.
its not cavitating at all, the boat has a ervin capps keel and stays loaded all the time, its just turnin the pump that hardTime for a full race prepped impeller, off the shelf stuff ain't gonna cut it for you.
thanx, ole mota is just insannnneeeeee!Tommy congrats to you and Billy , check your Pm's !
496, twin 75mm bullseyehow many ci & what size turbos ya running ? i just ordered a couple myself![]()
now why would he wanna do that?Just turn the boost down would ya..
Got any MPH #'s on that baby yet ?
S CP![]()
awsome ! i just got some 72mm (not arrived yet)can't wait to see some results. do they spool instantly? is there a little lag? what a/r ratio you running?do you know the turbine size ?or any other specs? what is your estimated hp?496, twin 75mm bullseye![]()
nooooo lagawsome ! i just got some 72mm (not arrived yet)can't wait to see some results. do they spool instantly? is there a little lag? what a/r ratio you running?do you know the turbine size ?or any other specs? what is your estimated hp?
dps did not make a Jetaway, He made a rachet'dps jetaway
Only the DPS rachet requires for the shaft to be cut and drilled for a pilot hole. And yes, it weakens the shaft. The Jetaway has a splined collar that slips over the shaft and increases the shock load capabalities of the shaft by 28%. This eliminates the twisted off shafts. Give me a call, I'll explain. 417-858-8616.he can't run a jetaway of any kind because where the shaft has to be cut for the pilot bearing, it'll snap the shaft at that weak spot.
ohhhh, good to knowImpatient 1
Only the DPS rachet requires for the shaft to be cut and drilled for a pilot hole. And yes, it weakens the shaft. The Jetaway has a splined collar that slips over the shaft and increases the shock load capabalities of the shaft by 28%. This eliminates the twisted off shafts. Give me a call, I'll explain. 417-858-8616. Duane HTP
so as your'e plaining out or poping up ontop of the water you have full boost?????nooooo lag1.32 ar, forgot turbine size i know the wheel is 75mm. 2000+hp?? not sure, let's just say its just got stupid hp/tq
blow thru carb, aeromotive belt drive fuel pump, 13202 aeromotive regulator with bypassso as your'e plaining out or poping up ontop of the water you have full boost???????? wow . i think my turbos are too small
i told them i wanted instant boost & they put me in the 72 mm & estimated @1350hp...if i get the motor enough fuel . how r u getting fuel ? mech injection? i am worried my cam ain't gonna cut it either . if your cam is not a secret i would like to know what u r runnin .
twin air to water ic's, there's more pics of it in forced induction , page 2 of my carb tuning threadlooks badass, you got a pic of the rear? is it innercooled?what brand carb?size 1250?
