Anyone heard of these. Engine is NA BBC 468, 12.5:1, 7500rpm race only hydro.
Tim
Tim
Yeah... company is out of Australia... I believe, and I'm sure someone will correct me if I'm wrong, but they were originally Repco. Not a bad part... used their "p" series equivlent for quite a few years on stockers and haven't had any issues. Haven't used their race coated bearings as of yet though.Anyone heard of these. Engine is NA BBC 468, 12.5:1, 7500rpm race only hydro.
Tim
Tim
We used an accumulator tank...Same thing basically...The problem with 20w-50, or any other multivis oil with a large differential is the polymers to make the different weights, more polymers means less oil, less oil can and sometimes does mean less lubrication factor (lubricity), keeping the weights close = less polymers.the site has some interesting information, but I wouldnt advise trying to run a High HP engine on 20W50, the viscosity simply isnt there to handle the bearing loads, and an Engines clearances determine the weight of Oil it has to Operate on, and nearly ALL the guys I knew Racing, built oil pressure cranking, then hit the mag and let the engine fire.
Run 5-30 in an 800hp NA BB Chev...been four years. Never been apart, never been hurt. I'd never try that in a blown app, though. Application is the key.We used an accumulator tank...Same thing basically...The problem with 20w-50, or any other multivis oil with a large differential is the polymers to make the different weights, more polymers means less oil, less oil can and sometimes does mean less lubrication factor (lubricity), keeping the weights close = less polymers.
Don't know where the multi vis discussion comes in, but there you go.
If you are turning 7500 RPM, I wouldn't recommend a very heavy or a multi anyway...Maybe just me, but run it tight and light...devil
a 20W50 Oil means it wont ever get less viscosity than a 20, nor more than a 50....many think it's just the opposite, but it isnt, and 20W50 in an engine with .0035.0045 mains and rod clearances, you DONT want to hear with mufflers, they rattle like shit. and 20W50 in an engine with Aluminum rods is asking asking for it, the oils running away from the parts faster than it's coming in. with .030-.050 side clearance, the oil isnt hanging out on the journal long.
You need to help me out here, what do you mean by "many people think the opposite"? Opposite of what?
What else could it mean?
I run Amsoils 0W-30 in my wifes CRV, the thing is a friggen kid taxi and I don't think it has warmed up more than four times in its 60,000 miles :|err
After a 7500 mile oil change, you could put it in another car it's so clean....
The last Honda we had had 345,000 miles on it, Amsoil from day uno....
I am not an advocate of multi vis in a boat with controlled oil temp, seems unnecessary, that's all....
Synthetic M1. For this application it's the thinnist oil I feel comfortable with and in a marine application with no oil cooler the oil temp swings can be quite extreme. Thin oil is less drag on the rotating assy, which yields more power. I believe in running as thin an oil as possible and still have the best protection.Just curious.....Why? .
There is no way, at 800 HP it could ever take advantage of the 5W, how cold can the oil get? Unless you use the boat in a frigid river, which we sometimes do, the oil gets a viscosity drop if it will be that cold for that long....
In our marathon days, guys would always say "run the 20W-50 dude!" but could never back up why...We had .0042 rod and main clearances and ran stright 30 HP synthetic...This was before the zinc deal, but this oil still has the added zinc (never had the scratch for a roller cam)...
My oil cooler runs off of the outlet water (measures about 120*F on average) and the oil gets to temp almost stupid fast (less than two minutes at a fast idle), so never saw the need...
from what I have read about a lot of oils (I sell Amsoil), the wider the differential, the more polymers, a differential of 20 If memory serves was like the cut off for added polymers...Depends on the manufacturer though, your specific oil may have none, which would be desired...
I only run multi vis oil in the daily drivers and stuff that takes forever and a day to warm up (my motorhome would be a perfect example)..
Thanks HAT, BTW I was in no way comparing my 140HP grocery getter to a BAE, simply using it as an example for what I would call a perfect use of multi vis oil....Although my motor home has a 468 EFI Chevy in it...Many think a multi vis is a 20 in the winter, and a 50 in the summer, ...I am talking average joes, and since some in these threads admit to not knowing alot, i am trying to clarify my posts as much as possible
I ran 50W Penzoil in ALL my Race engines, ALL of them, and between .0027- .0032 in all but Aluminum Blocks, I wont run ANYthing less than a 50W in an Aluminum block because of an experiment Mike Landy did on his, heated it to 200 degrees then measured the Mains....and it almost gave him a stroke,
I see no advantage of changing whats always worked for me, and i see only minimal HP increases from friction, to me it isnt worth the potential cost in High Dollar parts, ....
a CRV Honda is a little different than a 3400 HP BAE 6 on Alky thats getting a little in the pan each run.
Thanks Steel, I was just curious...Synthetic M1. For this application it's the thinnist oil I feel comfortable with and in a marine application with no oil cooler the oil temp swings can be quite extreme. Thin oil is less drag on the rotating assy, which yields more power. I believe in running as thin an oil as possible and still have the best protection.
