Its time to degree the cam. Its not the one i would have picked but its the one i have. It came with the engine. Bullet, 309/316, @.050 276/284, gross lift .731/.731, 110*, lash .026/.028 . Lunati link bar lifters. Comp pushrods, rockers, springs and girdle. Speed-Pro pistons L2307AF .100 over. Crankshaft Specialist crank. Steel LS 6 rods 6.135 . Dart Pro-1 heads. Block has been decked and piston is at 0 deck. Had to have heads shaved .020 to clear indentions because of previously ran copper head gaskets. Will install Fel-Pro 1027`s @ .039 . Will run two 850`s or one 1150. Mantra Performer medium weight hull. Berkeley "B". Droop snoot and place dirverter. It`ll be a lake boat. I`ve been told to degree it @ 108 to give me more on the bottom end. 108* is 30* BTDC. Maybe i should retard it 2* and gain on the big end? Or maybe straight up and have the both of two worlds? Is there really a measureable difference? Thoughts, opinions and advise welcome and thanks in advance. Richard
